Changing the class properties of sheet layer or design layer viewports
The class visibilities and attributes of a selected viewport can be changed from the sheet layer or the design layer. This does not change the class properties or the class visibility for the original design layers or for other viewports. The viewport attributes can be tailored for presentation; several copies of the same viewport can appear completely different. If the class properties in a viewport style are set by style, they apply to all viewports that use that style and must be edited from the Edit Viewport Style dialog box.
To override viewport class properties or viewport style class properties:
Do one of the following:
Select an unstyled viewport or a styled viewport with class properties set by instance, and then from the Object Info palette, click Classes.
Edit the viewport style, and from the Edit Viewport Style dialog box, click Classes.
The Viewport Class Properties dialog box opens. The dialog box functionality is slightly different for referenced (Vectorworks Design Suite product required) and non-referenced (internal) viewports. Change class visibilities and/or make class attribute overrides for the selected viewport.
Properties for design layer viewports, non-referenced (left) and referenced (right)
Parameter |
Description |
Search box |
Enter text to filter the list by name |
Filter list |
Select a filter for the list |
Manage Filters |
Opens a dialog box to add, edit, delete, or import filters for the class list; see Filtering and tagging classes and layers |
Class list |
Lists the viewport classes and their visibility and edited status; click on a class visibility column to change the class visibility for this viewport. Click the triangle in an active column to toggle between ascending and descending sort order based on that column parameter. |
Visibility |
Click on a class visibility column to change the class visibility for this viewport. Column 1: Visible (displays objects in this class) Column 2: Invisible (hides objects in this class) Column 3: Gray (displays objects in this class as grayed) |
(Source) |
Indicates whether the class definition is the same as the source class ( Non-referenced viewports: All classes use the document class definition by default. To change the appearance of a class in this viewport, click Edit and change the settings; the viewport-specific icon displays automatically. Click the Revert button to revert to the original settings. Referenced viewport: (Vectorworks Design Suite product required) Because they come from an external file, all classes show as viewport-specific by default. If the same class exists in both the viewport and in the current file, they remain completely separate. By default, the class definition in the viewport will be updated from the source file when the reference is updated.
(Update) (Referenced viewports only) |
Indicates whether to update the class definition from the source file when the reference is updated ( |
Edit |
Opens the Edit Class(es) dialog box, to make overrides to the selected class that only apply to the current viewport (see Setting class properties); drawing objects’ class setting should be "By class" to take advantage of class overrides. Edit is not available if the viewport is using data visualization with Draw all other objects grayed. |
Opens the Import Attributes dialog box, to import the class attribute settings from the file. The attributes can be imported for the classes selected in the Viewport Class Properties dialog box, from corresponding classes, or from a specified class in the file or a specified viewport. The Eyedropper tool can also transfer class override attributes between viewports. |
Revert |
Sets the selected class back to its original document attributes, undoing any class overrides; also removes the override icon in the Source column |
Use embedded design layer viewport settings for (Sheet layer viewports only; Design Suite product required) |
When enabled, the viewport retains the Class overrides and/or Class visibilities of embedded design layer viewports. These options apply only to embedded design layer viewports that are not referenced; referenced viewports are not affected. These options are available for unstyled viewports, and for styled viewports with Classes set by instance; for viewport styles, see Viewports use class overrides/class visibilities from embedded design layer viewport, described below. |
Use current document’s class visibilities (Design layer viewports only; Design Suite product required) |
When enabled, the viewport uses the current document's class visibilities. This option is available for unstyled viewports, and for styled viewports with Classes set by instance; for viewport styles, see Design layer viewports use current document's class visibilities viewport, described below. |
Viewports use class overrides/class visibilities from embedded design layer viewport (Sheet layer viewports only; Design Suite product required) |
Any sheet layer viewport that uses this viewport style retains the class overrides and/or class visibilities of embedded design layer viewports. These options apply only to embedded design layer viewports that are not referenced; referenced viewports are not affected. This option is available for viewport styles; for unstyled viewports and for styled viewports with Classes set by instance, see Use embedded design layer viewport settings for described above. |
Design layer viewports use current document's class visibilities (Design layer viewports only; Design Suite product required) |
Any design layer viewport that uses this viewport style uses the current document's class visibilities. This option is available for viewport styles; for unstyled viewports and for styled viewports with Classes set by instance, see Use current document's class visibilities, described above. |
Preview |
Click to preview the class visibility and attribute settings in the selected viewport |
